Can't open Helix native 1.10 ......Help
bzpobzpo
After  install Helix native 1.10 and start my logic pro 9 , i find that my plug in is missing ,and i try to reinstall  1.10 or 1.01 but still the same...
am i missing something? please help ! (my OS X Yosemite 10.10.5 )
Did you Logic's function to scan the plugin directories so that it finds the new Native plugin? You'll want to make sure to point it to the proper directory.
You need to run Logic in 64bit mode -
To switch, close logic. Then right click on the Logic icon in your applications folder and select "get info." There will be a check box that says "Run Logic in 32-bit mode." Uncheck that box and Logic will automatically open in 64-bit.
Logic pro 9 does not run under Mac OS high Sierra - so don't upgrade!
Thanks for the reply, I am using 64 bit already before install 1.10 everything is alright , I didn’t change any setting.....I just download 1.10 (for Mac) and click install without Uninstall 1.01 , is that a wrong step to ungrade? But I find that I can open 1.10 Native on garageband but logic is missing plugin...
  • 2 weeks later...
