hal3001 Posted December 22, 2017 Share Posted December 22, 2017 Just a quick question. I was just wondering if there was a quick way (option somewhere) to send a dry signal out one channel of the SPDIF connection? I usually just create a split and have that run directly to the outputs with the digital outs selected then record the left/right signals separately which works fine if I've set up the patch myself but a lot of presets have pretty much every available path in use. I run SPDIF from the Helix Rack into my Apollo 8 and would like to keep things digital if possible. I know I can run the dry out into an input on the interface but I really don't like all that conversion. Quote Link to comment Share on other sites More sharing options...
hal3001 Posted December 22, 2017 Author Share Posted December 22, 2017 I kind of solved my own problem today. Instead of plugging into the Helix and sending my wet and dry signal out SPDIF, I realized I could just up a hardware insert in Pro Tools on the SPDIF interfaces then just plug into either my HiZ on my Apollo or my ISA 428 and then use my Helix Rack as a standard insert. It worked really, really well. Quote Link to comment Share on other sites More sharing options...
