Sign in to follow this
adamftg
Mixer, A/B Path question
I play my pod directly into my amp, using only a few effects and completely bypassing the Pod's amp model. My signal flow can be seen in the attached image.
As you can see, the signal splits into stereo between the null amp block and mixer. If I'm playing directly into my amp stack, should I only use one of the 2 signal paths by centering it and muting the other one in the main mix window? Or should I keep them hard panned like in the picture? Will there be a difference in sound coming out of my cab?
Thanks
Edit:
I dont think the image uploaded properly. The signal is mono throughout my pre effects chain, then splits into two separate paths between the null amp block and mixer, then returns to mono out of the mixer into the null FX blocks.
