qwvb1111 Posted December 27, 2017 Share Posted December 27, 2017 Greetings, I bought a Line 6 Spider V Classic 15 three days before, the sales told me I can plug a 3.5mm earphone (can be used in smartphone) directly into the amp and mute the speaker. (I would like to practice it quietly which only me can hear the sound) But when I plug it into “CD/MP3†hole, the speaker still plays. Anyone here uses spider 5 classic 15 amps and know how to use headphone/earphone? Please advise, thanks! (I read the manual and it looks like I need to plug into “phone/record out†hole?) Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 27, 2017 Share Posted December 27, 2017 Yes - connect it to the phone-record out jack. The CD/MP3 jack is an input, not output, jack. Quote Link to comment Share on other sites More sharing options...
ADBrown Posted December 27, 2017 Share Posted December 27, 2017 The headphone jack on the Spider Classic 15 is a 1/4 inch, so you will need an 1/8" (3.5mm) to 1/4" adaptor. Quote Link to comment Share on other sites More sharing options...
qwvb1111 Posted December 28, 2017 Author Share Posted December 28, 2017 The headphone jack on the Spider Classic 15 is a 1/4 inch, so you will need an 1/8" (3.5mm) to 1/4" adaptor. does that mean 1/4†= 6.3mm plug? Quote Link to comment Share on other sites More sharing options...
thorneven Posted December 28, 2017 Share Posted December 28, 2017 does that mean 1/4†= 6.3mm plug? Yes -> http://www.metric-conversions.org/length/inches-to-millimeters.htm Quote Link to comment Share on other sites More sharing options...
qwvb1111 Posted December 29, 2017 Author Share Posted December 29, 2017 The headphone jack on the Spider Classic 15 is a 1/4 inch, so you will need an 1/8" (3.5mm) to 1/4" adaptor. Yes -> http://www.metric-conversions.org/length/inches-to-millimeters.htm Do you know how to tune using this amp? I donr know the correct led indicates what... thx Quote Link to comment Share on other sites More sharing options...
thorneven Posted December 29, 2017 Share Posted December 29, 2017 Do you know how to tune using this amp? I donr know the correct led indicates what... thx The tuner on the amp is not very stable i.e. it vacillates/drifts quite a bit. I use a clamp-on tuner. It should be clear in the manual - have you checked? - and on the amp. You press and hold the Tap/Tuner button. Quote Link to comment Share on other sites More sharing options...
guitardad123 Posted December 30, 2017 Share Posted December 30, 2017 Tuner stability is improved on most any digital tuners when guitar pickup selector is in the neck position. Quote Link to comment Share on other sites More sharing options...
