ConnerNA Posted December 27, 2017 Share Posted December 27, 2017 Does anyone know if the Helix passes both MSB and LSB values? Here is the scenario I am sending a bank select and program change from my PC to my BeatBuddy that is connected to my Helix via Midi (using the Helix as the midi controller). PC (usb) -> Helix -> (midi) BeatBuddy My program change sends are working but the bank select that requires both MSB and LSB values is not. I am starting to suspect that the Helix is NOT passing these values along. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted December 27, 2017 Share Posted December 27, 2017 As a test, try sending your MSB/LSB/PC directly from the Helix to your Beat Buddy. Use a MIDI monitor on your PC to be sure the Helix is sending correctly. If the BankChange/PC works that way, then you may be right about the Helix not passing the full message, and you'll need to open a support ticket. If it doesn't work, but Helix is sending the correct messages, then it could be a timing problem. I found that sending MSB/LSB/PC TO the Helix from a FCB1010 had the problem you described, PC works but no Bank Change, but sending the same messages to a SoftSynth worked fine. Quote Link to comment Share on other sites More sharing options...
