dornstein Posted December 28, 2017 Share Posted December 28, 2017 Just now trying to get my Windows 10 PC (Surface Pro) to connect to my new (awesome!) Helix. The driver is not working. I installed version 1.87 (the latest version of the driver). I've done a fair number of installs, and eventually did a full uninstall and then reinstall, rebooting each time in between (and having the Helix not plugged in). That appears to be all the advice in the forums available. I'm using Chrome to download, so don't have the issue about driver signing -- I think. In the Windows Device Manager the Line 6 Helix driver shows with an error exclamation point icon. The error text says: "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) {Bad Image} %hs is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support. Error status 0x" I know my way around a Windows PC pretty well (worked at Microsoft for the past many, many years). Any suggestions? I'm dead in the water. Can't do any design work, download anything, update the firmware, etc... :( Thanks, David Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted December 29, 2017 Share Posted December 29, 2017 Just now trying to get my Windows 10 PC (Surface Pro) to connect to my new (awesome!) Helix. The driver is not working. Any suggestions? I'm dead in the water. Can't do any design work, download anything, update the firmware, etc... :( Thanks, David Open a support ticket with Line 6 and have them help you out. Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted December 29, 2017 Share Posted December 29, 2017 Did you download and install the HX Edit software on your Surface Pro? That contains the actual device driver for the Helix. Quote Link to comment Share on other sites More sharing options...
dornstein Posted December 29, 2017 Author Share Posted December 29, 2017 Did you download and install the HX Edit software on your Surface Pro? That contains the actual device driver for the Helix. Yes, I did. I tried installing the driver separately too. All produced the same result. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted December 29, 2017 Share Posted December 29, 2017 I would definitely start with an uninstall of the driver and Helix software from the Windows 10 "Control Panel --> Programs and Features" and then reboot the PC, and do a fresh download of HX Edit from Line6 which will include the latest driver. It sounds like you are getting either the wrong device driver or your device driver is getting corrupted in the download process somehow judging by the error message (but not necessarily). Reinstalling the correct version of HX Edit for your OS is the easiest way to guarantee you are getting the correct driver for your OS. If the above does not work and given your familiarity with Windows and former employment with Microsoft these may all be things you have tried already but here goes. Get a fresh download of the correct driver. One approach you may have already tried is right clicking on the driver in Device Manager and attempting to update it from the list of local drivers already on your machine (rather than updating from online). A fresh install might be best though. Continue to uninstall the driver first before any attempts to reload it. Have you tried loading the driver with your anti-virus software turned off including Windows 10's Defender? You might also try unplugging anything else in the USB ports and disabling every unnecessary process running on the PC for the duration of the driver install. This may include going into the Task Manager and killing unnecessary processes. Quote Link to comment Share on other sites More sharing options...
dornstein Posted December 29, 2017 Author Share Posted December 29, 2017 Thanks for the suggestions, HonestOpinion . Unfortunately, I've done almost all of them already to no avail. Uninstall/reboot/install HX edit. I've also downloaded the driver a number of times, with various browsers to avoid anything IE specific (like issues with signing). I've had nothing plugged in to the USB port for this. I'll try with defender turned off to no avail (though I would have expected a message or something if it intervened). Not sure what set of processes would be "unnecessary" ;-) I have opened a support ticket, though I would still very much appreciate any other suggestions.... Thanks for the suggestions, HonestOpinion . Unfortunately, I've done almost all of them already to no avail. Uninstall/reboot/install HX edit. I've also downloaded the driver a number of times, with various browsers to avoid anything IE specific (like issues with signing). I've had nothing plugged in to the USB port for this. I'll try with defender turned off to no avail (though I would have expected a message or something if it intervened). Not sure what set of processes would be "unnecessary" ;-) I have opened a support ticket, though I would still very much appreciate any other suggestions.... Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted December 29, 2017 Share Posted December 29, 2017 Thanks for the suggestions, HonestOpinion . Unfortunately, I've done almost all of them already to no avail. Uninstall/reboot/install HX edit. I've also downloaded the driver a number of times, with various browsers to avoid anything IE specific (like issues with signing). I've had nothing plugged in to the USB port for this. I'll try with defender turned off to no avail (though I would have expected a message or something if it intervened). Not sure what set of processes would be "unnecessary" ;-) I have opened a support ticket, though I would still very much appreciate any other suggestions.... Here is a really good link on the (Code 39) error you are getting: https://www.lifewire.com/how-to-fix-code-39-errors-2623185 It could be you have a bad registry entry. A fairly extreme measure for a failed driver install but one of the things you can try is restoring to a recent restore point (if you have one) before you first updated the Line6 driver. I suppose you could do a registry backup using regedit and try to find the bad entry(s) and manually delete them but I wouldn't know where to start there. This all assumes a bad registry entry is even the issue. Quote Link to comment Share on other sites More sharing options...
gk001 Posted January 24, 2018 Share Posted January 24, 2018 There are issues with other Line 6 drivers and latest Windows 10 version here, could be related http://line6.com/support/topic/25115-constant-bsod-with-line6-drivers/?p=241920 Hope you find a solution Quote Link to comment Share on other sites More sharing options...
robvde Posted April 13, 2018 Share Posted April 13, 2018 Any updates on this one ?. I have exactly the same with the HD POD 500x though I do run the very latest builds of Windows 10 (RS4). Had in consideration to replace the 500x with Helix but guess it's better to wait a bit. Quote Link to comment Share on other sites More sharing options...
TTRESHH Posted May 16, 2018 Share Posted May 16, 2018 +1 awaiting for some ideas cause i tried everything to solve my code 39 problem. HelixEdit working fine some days. but in one moment all gone, except code39:( Quote Link to comment Share on other sites More sharing options...
bsewart Posted May 17, 2018 Share Posted May 17, 2018 Which surface do you have? I manage 60 surface 4 pro's and a mix of surface 3 Pro's and RT's I have found many issues are fixed with current software for them. not sure of your foray into this area so forgive me if this is stuff you have done already or know all about. MS have mad my life so much easier with bundling drivers and firmware updates to various parts of the surfaces in a single file. just run the .msi and all drivers are updated and firmware as well in one fell swoop. do a winver and look at your win10 build. Download just the appropriate file for your system. latest supported Surface pro3 win 10 version is v1703 (10.0.15063) latest supported Surface pro4 win 10 version is v1709 (10.0.16299) Surface 3 Pro: https://www.microsoft.com/en-us/download/details.aspx?id=38826 Surface 4 Pro : https://www.microsoft.com/en-us/download/details.aspx?id=49498 it could be just a slight bug/hiccup in your system the driver borks at. I advise to also download the latest cumulative update to windows as well. go to the following and click the "Last Updated" heading to sort by most recent and download .msi to bring windows fully up to date. 1709: https://www.catalog.update.microsoft.com/Search.aspx?q=Cumulative Update for Windows 10 Version 1709 1303: https://www.catalog.update.microsoft.com/Search.aspx?q=Cumulative+Update+for+Windows+10+Version+1703 BTW if your surface has applied the 1803 upgrade, good luck as I have had some issues with it! Reason why I am not focusing on the driver is sometimes a bad OTHER driver stops a different one working right such as a vga card or audio. before you start, maaybe uninstall helix driver and reinstall after updating everything. once again, sorry if this is preaching to the choir good luck!! Quote Link to comment Share on other sites More sharing options...
fl1ckmeister Posted April 19, 2021 Share Posted April 19, 2021 Any updates on this? My helix worked just fine until recently, I am having the same issue. Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 19, 2021 Share Posted April 19, 2021 52 minutes ago, fl1ckmeister said: Any updates on this? My helix worked just fine until recently, I am having the same issue. Hi, You post is a little vague, and this thread has been quietly snoozing for almost 3 years! You say that your Helix “worked fine until just recently” - therefore, what changed? What exactly is the issue you are having and on what platform - it’s really helpful to know this important stuff. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
chzwizz Posted December 19, 2021 Share Posted December 19, 2021 Just bought a Surface 7, downloaded and installed the latest Line6 SW, and see the same error (code 39) in the device manager Line 6 Helix Properties . Hxedit is actually working fine. But of course audio to the device is not. I've unistalled and rebooted and re-installed several time.. :( I've installed several win10 updated, so that it claims that there's no new updated (I did not install version 21H1, yet but I didn't have that on my previous computer). The only other SW I installed so far was audacity.. Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 19, 2021 Share Posted December 19, 2021 9 hours ago, chzwizz said: . … But of course audio to the device is not. …. HX Edit (which I assume is the SW you are referencing) does not pass audio to the Helix device. It sends and receives command and control information only. The audio is produced by the Helix. If HX Edit seems to be working but you are not hearing audio make sure your speakers or headphones are connected to your Helix, not your computer. 1 Quote Link to comment Share on other sites More sharing options...
chzwizz Posted December 21, 2021 Share Posted December 21, 2021 Yes , I installed HX Edit and the USB drivers. I have 3 other Win10 PCs around the house which all worked. Ie HX Edit can control the helix AND Audacity is able to use the helix as the playback device over USB. This 2nd function was not working on the surface pro 7 The following link provided a solution. USB Driver install on 64 Bit Windows 10 Code 39 Driver Error - James Tyler Variax Guitars / Workbench HD - Line 6 Community Now I can use the Helix for audio input and output as well as editing the patches with Hx Edit. Line 6 should look into this.. It's likely an issue with the provided driver. It would be good to leave that Core protection enabled.. But I'm super happy for a solution I do really , really like the helix for what I'm doing.. Quote Link to comment Share on other sites More sharing options...
Maralf50 Posted August 27, 2022 Share Posted August 27, 2022 help help driver not recognized Quote Link to comment Share on other sites More sharing options...
H3R3T1K Posted February 13, 2023 Share Posted February 13, 2023 Has this been resolved? Error from today on fresh HX Edit install. "a driver couldn't be loaded on this device" (HX Stomp, Win 11 x64 up to date). "more information" leads to a how-to disable core isolation. Quote Link to comment Share on other sites More sharing options...
datacommando Posted February 13, 2023 Share Posted February 13, 2023 On 2/13/2023 at 11:57 AM, H3R3T1K said: Has this been resolved? Error from today on fresh HX Edit install. "a driver couldn't be loaded on this device" (HX Stomp, Win 11 x64 up to date). "more information" leads to a how-to disable core isolation. Hi, Maybe you should read this:- Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
