Tattootony412
Looper on spider5 120w delay
Well I was told that the mk2 works as a looper. Not true. Sooooo why is there a delay with the actual button on the amp. No matter what I do. Can anyone help with this. I don’t have a pedal as of now.
Also what the best floor board to use with this amp.
The best floorboard to use with the Spider V series is the FBV3. The looper is activated the very instant it is pressed, which means manually pressing the loop button on the front of the amp to start and stop recording while also simultaneously playing guitar can be prove difficult when trying to make an in time loop.
yeah ill be getting one of those. The looper still has a delay though. even if im strumming with one hand and press the button with the other. Alway a 2 or so second delay at least....is there a timer or something
The looper is activated as soon as you press the button, there shouldn't be any delay. If you are certain there is a delay when using the loop button on the front of the amp, and it is not caused by human error, then you should open a support ticket to ensure the amp is properly functioning. I would also recommend performing a factory reset first.
