My Helix 4CM/7CM setup
VirtualGuitars
Hello, I wanted to share my Helix 4CM/7CM setup with my two Marshall tube amps for those new Helix owners.  I also have two Gibson Les Paul reference monitors on my desk connected via the XLR outputs.  I bought a 30-foot USB cable to connect my Helix to my MacBook Pro which is on the other side of the room.  I am very pleased with the results!  I hope this helps somebody that hasn't tried the 4CM or 7CM.  This is just for me at home, so please forgive my poor cable management.  As an IT professional, I have to admit it could be a lot better.  :)
4 Cable Method (4CM) for Amp #1
Cable #1 Guitar to Helix Guitar In
Cable #2 Helix FX Send Loop 1 to Amp #1 Main Input
Cable #3 Amp #1 FX Send Loop to Helix FX Return Loop 1
Cable #4 Helix 1/4" Left (mono) Out to Amp #1 FX Return Loop
7 Cable Method (7CM) for Amp #2
Cable #5 Helix FX Send Loop 2 to Amp #2 Main Input
Cable #6 Amp #2 FX Send Loop to Helix FX Return Loop 2
Cable #7 Helix 1/4" Right Out to Amp #2 FX Return Loop
  • Upvote 3
  • 8 months later...
Thanks for this great write up. I want a two amp set up....not stereo though. Basically a clean amp and dirty amp used at separate times.
I'm using a Marshall Silver Jubilee Mini combo for dirty sounds.... and looking into a Boss Katana or Bluesbreaker 15 for cleans only. I want to use Helix's effects with both loops. I assume 7cm will allow for this. My big questions are:
1. how do you set up the Helix to switch between the amps.
2. is there a specific way to set up the outputs on the patch to run with two amps?
You're welcome, man.  That's what this community is all about.
1. I run both amps in stereo using the 7CM.  I use Path1 for Amp1 panned left and Path2 for Amp2 panned right.  I use two Mini Jubilees now, but you can use whatever you have.
2. I basically have the same effects in both paths - one for each amp.  I have FX Loop 1 on Path1 and FX Loop 2 on Path 2.
11 minutes ago, djpgreek said:
Ok, so when you stay you run em stereo...you're using both at once? I just want one at a time and switch between
Yes, I am using them both at once.  I suppose you could could use just one amp at a time using the 7CM; however, your patches would need to point to the correct FX Loop.  In other words, you'd have to have separate patches for each amp.  Never tried it that way.
  • 9 months later...
I am going to use the Helix with two amps in stereo. H&K Grandmeister 36 and a H&K Blackspirit. I plan to use the 7 cable method. A question is if I use 7 cable method, can I choose to have certain patches where I have the Helix amp models working and run it through just the power sections of my amps and then at other times use the preamp of those amps?
Also, I have a Lifeson Les Paul with the two output jacks, one for Buckers and the other for Piezo. I would like to run the Piezo in the Aux input and then use one of the free loops to send to a Fishman acoustic amp. Not sure how to hook that up.
Thanks
