herbedaceous Posted January 20, 2018 Share Posted January 20, 2018 Looking for help with this problem please: My Recently purchased Variax Standard Guitar gives a loud unpleasant Squealing screeching noise intermittently with acoustic models. Never happens (so far) with other models. Noise continues until I switch off or unplug Guitar. Wanted to use in a live situation but need this rectified first! I’m Using variax with standard guitar lead straight into an Alesis USB mixer and I have updated firmware and ensured battery is fully charged. Is this a known issue? Any help appreciated please Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 22, 2018 Share Posted January 22, 2018 If it's a whistling howling sound in Alt Tune mode or Acoustic 12-string, then probably the intonation needs to be dialed in a little tighter. If it's a warbling distortion, then it's more than likely the pick-up distance to the strings needs to be adjusted. Either way, it sounds like a set-up issue. I use acoustic Models to check for this sort of thing when I service these guitars as the resonance quality and harmonic content of those Models brings that out more. Quote Link to comment Share on other sites More sharing options...
herbedaceous Posted March 3, 2018 Author Share Posted March 3, 2018 Update on this issue, Guitar went back to LINE 6 who replaced the main internal component and it’s working fine now 😄 Quote Link to comment Share on other sites More sharing options...
bsabah Posted March 22, 2020 Share Posted March 22, 2020 Hello, I have the same issue when I use Pod Farm and any recording program. Ableton, Garage Band, and Reaper. By any chance do you know which internal component was? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted April 21, 2020 Share Posted April 21, 2020 Make certain that tuning and intonation are spot-on. Quote Link to comment Share on other sites More sharing options...
