cmorrow132 0 Posted October 10, 2013 So hoping someone else has encountered this issue and knows a fix. I am running vmware fusion on OSX 10.8.5 with Win7 x64 as the guest. I installed the Line6 Monkey, the hd500 drivers and HD500 Edit in the VM. The pod shows up, but all I get is distorted sounds and sometimes beeps from the pod. The pod works flawlessly in OSX. The reason I want to run in a VM is to use a DAW that doesn't work on OSX 10.8. Any ideas on how to get this to work in a vm? Quote Share this post Link to post Share on other sites
TheRealZap 7,366 Posted October 10, 2013 I had less than stellar performance using parallels... even bootcamp was less than perfect, but better once i got the right drivers. what DAW, and what is it that you like so much that you can't give up? Quote Share this post Link to post Share on other sites
joel_brown 367 Posted October 10, 2013 Good luck... I know that isn't helpful but you're sticking your hand in the fire and asking how not to get burned. Quote Share this post Link to post Share on other sites
redlight7777 4 Posted October 10, 2013 Cmorrow123 Get yourself a copy of reaper which works on both platforms pc and mac. They have a full copy on their website for $60 It works well on both pc and mac platforms. Then you can stay in 10.8.5 until mavricks becomes available. It will save you the headache. There is a learning curve. Reaper.fm Hope that helps you a bit. And it doesnt break the bank Quote Share this post Link to post Share on other sites
cmorrow132 0 Posted October 18, 2013 Thanks for the responses. I've ended up settling for reaper for now. It's not what I'm used to, and feels a little rugged compared to Sonar, but it works. Quote Share this post Link to post Share on other sites
