Pod XT Pro and Scarlett 18i20. How to setup S/PDIF
I've got a used Pod XT Pro which is connected to to Focusrite Scarlett 18i20 (1Gen) via S/PDIF.
The problem is, that I do not know/understand how to setup both devices to get the signal from POD to Scarlett.
The Scarlett is configured using MixControl
SampleRate 41.1kHz
Sync Source S/PDIF
Sync Status Locked
USB Driver Connected
ASIO Buffer Size 6ms
The POD XT Pro is setup using I/O & Dig Select
Input Guitar
Format 41.1kHz 24 Bit
Mode Normal
Gain +0db
Having plugged a guitar in I see the signal led flashing. I also get a signal on the DI Out which I also connected the interface using 1/4inch.
In MixControl I can see the level meters receiving signal on the analog input, but not on the S/PDIF ones.
When I change the POD to 'Match S/PDIF' in the IO Select, still no signal can be received. When I restart the POD with this setting it gives a message saying:
"CANNOT LOCK TO INPUT. WAIT FOR RE-CLOCK OR PRESS ANY BUTTON TO SELECT GUITAR IN AND 44.1kHz 24 BIT OUT."
Can anyone help me out here, how to setup this correctly.
Many thanks
Sebastian
