The only way that I can think of without having the unit in front of me is to do a split before the loop with a volume block after and then merge the signal after that
chitlun 0
I just got a Helix and am exploring the Looper section. I would like to be able to fade the looper while still having the guitar output play through. I followed instructions to add an external expression pedal (set up on Exp Pedal 3). While I was able to set up the playback to fade via the pedal, it also fades what I am playing as well. I also want to achieve this in stereo as i run stereo loops with panned parts, etc.
I used to use an old Line 6 DDL-4 for loops and one function I loved was that I could set up the loop to fade with my pedal, while still playing through (in mono of course). Made for less choppy endings. Much more fluid than a hard stop.
Is their a way to achieve this with the Helix Looper? I'd like to be able to stay "in the box" and not go to an external looper.
Thx.
I use the on board exp pedal mapped to Loop playback level and that works fine for me. I have overall volume mapped to EXP2 (default) & Loop playback to EXP 1.
Thanks, this worked!
chitlun 0
:) Glad to hear it...
Thx.
