Sign in to follow this
dudluu
Volume Pedal changes "drive" parameter of amp setting
Hi y'all
In all patches in the firehawk when I move the volume pedal it sets the "drive" of the amp setting to another position than programmed.
First I thought the "drive" is assigned to be tweaked by the pedal, but as far as I know you can not tweak amp settings with the pedal.
I calbirated the volume pedal but this did not help at all.
Example:
"drive" is programmed to 80%. Sounds nice.
Now I move the pedal to adjust the volume and the volume is controlled nicely, but also the "drive" parameter jumps to somewhere around 50%. When I move the pedal again the "drive" never goes back, it moves between 40 and 50%. No chance to bring it back up to its initial setting.
Firmware version. 1.30
Anybody the same problem? Solutions?
Thanks!
I wasn't aware that the pedal could not be assigned to amp parameters. Are you sure about that?
Have you checked the pedal assignment using the Firehawk app? It certainly sounds like it is assigned to the amp Drive parameter, and set to a mid-range sweep.
I'm having this exact same issue, only mine cuts the amp drive to 1% whenever I use the volume pedal.  Did a factory reset and I'm still having the problem.
All of this is very confusing because you're not supposed to be able to assign the pedal to amp parameters.
Create an account
Register a new account
Sign in
Sign In Now
