checkolade Posted February 4, 2018 Share Posted February 4, 2018 Hi everybody, I've got a problem with my POD HD 500X. I have created 2 new dual amp patches (hard panned left/right) with the same problem: While editing with the Edit software on my PC, everything sounded fine. But when I switch the patches the POD doesn't seem to load one of the amps, so one stereo channel seems "dead". No difference if I switch via hardware footswitches or via Edit software. It's funny, because when I click in the Edit software in the Main Mix section just on the level fader without any change in value, the channel starts to work again. I could find anything like that via the search option, so I would be very happy about any suggestions. Thanks :) Quote Link to comment Share on other sites More sharing options...
checkolade Posted February 4, 2018 Author Share Posted February 4, 2018 Hey Guru, thank you very much! I re-built the patches on the POD directly and everything works. Obviously a bug in the Edit software. For now I know better :-) Thumbs up! 1 Quote Link to comment Share on other sites More sharing options...
Smashcraaft Posted February 7, 2018 Share Posted February 7, 2018 Checkolade, is it possible, that you accidentally (or based the region you are living in) used comma instead of a period, when typing in values? Any info about that could separate the bug a little more. Quote Link to comment Share on other sites More sharing options...
checkolade Posted February 11, 2018 Author Share Posted February 11, 2018 When typing in values, I use "," if necessary. Mostly I just play with the knobs in the Edit software to find my sound :) I'm also from Germany. Quote Link to comment Share on other sites More sharing options...
Smashcraaft Posted February 12, 2018 Share Posted February 12, 2018 When typing in values, I use "," if necessary. Mostly I just play with the knobs in the Edit software to find my sound :) I'm also from Germany. Meanwhile I am pretty sure that the comma "," leads to a wrong input value and causes the bug. Thank you for clarification! Quote Link to comment Share on other sites More sharing options...
