Pod Hd Desktop: Recording Inputs 1 And 2 To Separate Tracks
Here's a preset you can use as a model. I created it a long time ago so that you could record the Wet and Dry signals simultaneously from the Pod, but you can adjust as desired EXCEPT don't mess with the signal flow structure - don't put anything before the path split. Read the comments with the preset for DAW setup.
http://line6.com/customtone/tone/217206
Also, this was created for the Pod HD500. TYo use it with the HD Desktop you will need to run it throught the Pod HD patch converter utility:
http://www.jzab.de/content/pod-hd
