Sign in to follow this
EugenCaraiani
Expression pedals(Exp 1 and Exp 2) do not switch
So I use for Helix for more them half a year I think so I know how to use it and I know that to change between those two you need to step hard enough on the pedal, and it worked good till this monday. Now it does not change as good as it did. I have to push a lot harder and even when I do it doesn't switch in most of the times. And when it does there is also a problem that I see that it changes for a moment and then goes back like I pushed it twice(which, of course, didn't). Couldn't find anything on this topic by myself, so hope someone can help me with this.
Are you using a Mission SP1-L6 pedal? If so, that switch can be adjusted by loosening and re-tightening the nuts. I have mine set to a hair trigger. As far as not switching now, use your fingers and switch it. If it switches this way it's just an adjustment that needed.
