Sign in to follow this
heavymetaldave
How To Run POD HD500X into Line6 AMP
I recently purchased a POD HD500X. I already have a Vetta II amp and Spider Bogner amp. Has anyone run the HD500X into these amps? How did you set it up?
David
You can hook it up anyway you want. Everyone has different needs, which then leads them to hook it up different ways.
I have a Flextone III XL, SV, SV MK2, DT50 and DT25...When I use the HD with any of those, I go power amp in...Generally COMBO power amp mode...STACK power amp mode is usually too scooped sounding for what I want to get...
For the Vetta, you will need to put a dummy plug into the guitar input to turn on the power amp as it is switched on the input jack....Flextone III XL is the same...These amps actually work very nicely with the HD as you can run stereo and all that....
