Footswitch controlled parameter, like runaway feedback
aaronlyon
Helix floor. Firmware 2.50. Interested in your idea.
You just assign the feedback parameter on the delay to a footswitch controller. It's described on pg 42 of the manual. Just hold down the knob under the feedback parameter, and that will take you the Controller Assign screen. Hit Knob 6 for "Learn Controller" and hit the footswitch you want to assign it to. Then set the max and min values. You probably want to set the min to be the same value as you have set for the saved value in the preset. Set the max to something close to 100... Sometimes having the feedback all the way up is too uncontrollable.
Thanks, but I've done that process. I can clearly see that the footswitch is assigned to the feedback parameter, with min:0 and max: 100%. But pressing the FS does not change the value. I will try again with a blank preset, so other assignments don't conflict...
