rsvette12
Transfer License Question
You can download the Line 6 licensing tool and de-authorize the old one. It’s also worth noting that you can license it on up to five systems.
Thank you so that tool works for Helix also - thought maybe you do it right in helix now ?
The Line 6 licensing tools is a standalone application.
Yes thank you used it with older line 6 stuff was not aware it was still being used for Helix products
Just as I thought here is LIne6 reply - hope it helps others
Hi Richard,
You are correct. Within the Helix Native software you may navigate to the setting menu using the "cog wheel" to de authorize the computer associated with your Helix Native License. This will prevent you from losing one of your authorizations.
Kody Line 6 Support
Hi Kody,
I just posted a question about this, so can u give me a step by step on what I need to do to get my new computer to work with my Helix floor unit that already had version 2.5 on it? My old ones screen busted so I'm am trying to get a backup laptop going. Thanks
Hi Kody,
You can get your helix running on your backup computer just loose one authorization whatever that means I mean you did buy it anyway you have 5 authorizations so you loose one no big deal just unauthorized it next time on a working computer, because your computer crashed you dont have a choice
Ok, Ive had this a while and forgot the authorization process. I have downloaded all kinds of crap on backup computer. I can see my Helix but am sure it's not right.
You will have to re-authorization on your new computer and should be good to go - I found it takes at least 24 hours to get a ticket answered fyi
Ok, once I authorize computer, what do I need to download on laptop to use helix!?
Are you authorizing a floor unit or helix native or both ?
You download Helix Native from here then load it into your daw then authorize it from inside daw when you launch helix native on a track layer in Helix software is a round wheel down the bottom left side click that and authorize there
Helix Floor,
Helix Native is more money at a discount if you own a floor - having a sale rgiht now also 30% off suggest you get it right away going to run out otherwise its 99$ I think for floor unit owners - its awesome
I need to install a Helix software of some type onto my laptop first don't I before I buy and add native?
No you can download it right now and trial it for quite a bit of time 10 days or more cant remember, then you can buy it actually right in Helix if you want while in your daw there is a button to purchase now - I bought mine from sweetwater but buying direct from Line6 would be easier also you have floor unit so I would just buy from Line6 as they know who you are and the discount you should get
Ok thanks, but what software do I need to download so I can use my helix? 2.20? 2.21? 2.3, not sure what to download on computer now to be able to use and edit Helix floor unit.
You go here
https://line6.com/software/
under all software pull down pick Helix Native and to the right your operating system - then hit go button
1.5 Helix Native shows up - scroll down and click get download - thats it good to go you can install it tell your daw where the Helix vst is (make a sound track layer like for your guitar then load the helix vst and the helix menu will show up - everything you need to do is right there or you could just go to line6 shop and buy it - it will tell you how much it is put in that sale code to get discount
Remember Helix Native has nothing to do with your floor board to different products - hence the different versions 1.5 vs your 2.5
Keep in mind helix Native is limited right now on midi control - update is coming for that - right now your floor will work great with pedals - Native not so easy until full support is added
So you are saying that the Native is NOW the editor? You no longer download the 2.2 version on to ur laptop with the editor in it?
No Native is a different program it does not use the floor unit (its standalone) - a less expensive way of having helix if you dont want to pay for an expensive floor unit
Well that's useless to me. I have the floor unit and am trying to get my laptop to connect to it. Thanks for the education on the native. Need education on the helix computer software though. Anyone else out here that can help me?
Then go to Helix forum this is Native forum
http://line6.com/support/forum/86-helix/
Did not realize that. Sorry
No problem I did the same thing posted Native question in helix floor forum when I was looking into Native
Pretty simple Pete
Go to your purchase history in you account
On the right hand side under heading total you will see the word gift next you your helix native purchase - click it
Create an account
Register a new account
Sign in
Sign In Now
