kondradd23 Posted March 20, 2018 Share Posted March 20, 2018 I'm new user of helix family products and at this moment it is hard for me to understand the way how to create and use snapshots. Can you guys explain me the way how to use it? Quote Link to comment Share on other sites More sharing options...
rvroberts Posted March 20, 2018 Share Posted March 20, 2018 Why don't you just go to youtube and watch the videos? I put this into youtube search - How to use snapshots for line 6 Helix I got this and a whole lot of others - Quote Link to comment Share on other sites More sharing options...
ADBrown Posted March 20, 2018 Share Posted March 20, 2018 Snapshots let you make self contained variations of a preset. Meaning if you switch between snapshot 1 and 2, multiple effects could be turning on and off, and any parameters on the effects can also change. For instance my effects might be: comp, overdrive, chorus, delay, reverb. In snapshot 1 just comp and reverb are on, in Snapshot 2 reverb and comp turn off and chorus and delay come on, in Snapshot 3 all effects are on, in Snapshot 4 I have only reverb and delay but the mix has jumped up 30%. To access Snapshot mode press the bank up and down foot-switches while in preset mode. Select which snapshot you want to make your changes to (1-4). Select which effects you want off or on per snapshot. To make parameter changes press and turn on one of the 3 rotary encoder knobs, you'll see brackets appear around the parameter, that means that parameter will change between snapshots. Quote Link to comment Share on other sites More sharing options...
jwoertz Posted April 28, 2018 Share Posted April 28, 2018 I hope they add a "six presets / 6 snapshots" mode. Four of each isn't enough. Quote Link to comment Share on other sites More sharing options...
