RustyMartin Posted March 21, 2018 Share Posted March 21, 2018 I just got the Mission Aero EP- 25- Pro, very sweet pedal BTY! So far.... but.... I connected it to HXFX, EXP 1, learned the EXP 1 to increase decay on a reverb, or increase feedback on a delay. Set the parameters to 0% heel and 100% toe. Problem... Starting at heel down I'm at 0%....midway through the sweep to full toe it goes to 100% and begins to descend back down to 0% and is at 0% again at the the toe. Starting from the Toe position at 0% as I pull the pedal back towards the heel, the same thing happens... 0% Toe....midway 100% descending back down to 0% finally resting at the heel... I have tried all three outputs on the Mission, 1 and 2 act the same, 3 does nothing. I am using the same cable I was using on the last expression pedal that worked fine. (Line 6 EP) The cable is a single ring.. I would like to be able to go from 0% at the heel to 100% at the toe, and vice versa. Is this possible with this pedal? Any help would be GREATLY appreciated!! Quote Link to comment Share on other sites More sharing options...
caberto1981 Posted May 10, 2018 Share Posted May 10, 2018 Did you managed to solve this issue? It is maybe that that pedal was designed to be used with a trs cable? Quote Link to comment Share on other sites More sharing options...
RustyMartin Posted May 10, 2018 Author Share Posted May 10, 2018 Actually I did solve the problem! Thank you for asking. I opened the pedal up. Inside is a a few dip switches. I think there was one for all three of the outputs. I simply moved the switch to the other position for the output I was using and just like that.... problem solved!! Quote Link to comment Share on other sites More sharing options...
