LaurentBrondel Posted March 27, 2018 Share Posted March 27, 2018 My L2t sounds terrible with weak, distorted and intermittent sound on all inputs expect the AUX cinch IN's which sound fine. My hunch is it's an AD/DA conversion issue, I opened a ticket yesterday with Line6 support and haven't heard back yet. Is this something somebody has experienced and can easily be solved? Software/firmware issue, reboot, or hardware? Quote Link to comment Share on other sites More sharing options...
flanger68 Posted March 27, 2018 Share Posted March 27, 2018 Sadly, i can't say i ever experienced this...i assume you have tried various sources, to exclude the problem comes from the source you are using... ? Quote Link to comment Share on other sites More sharing options...
LaurentBrondel Posted March 27, 2018 Author Share Posted March 27, 2018 2 minutes ago, flanger68 said: Sadly, i can't say i ever experienced this...i assume you have tried various sources, to exclude the problem comes from the source you are using... ? Yes, of course. The 2 inputs on the mixer and the LINE IN exhibit this issue, whereas it is a mic, a guitar or a bass, XLR or 1/4". The AUX sounds fine though, exactly the same as my L2m. Quote Link to comment Share on other sites More sharing options...
LaurentBrondel Posted March 28, 2018 Author Share Posted March 28, 2018 Update: when I connect my L2t to an L2m through the Line6 link system, whatever is plugged in the mixer of the L2t comes loud, clean and clear on the L2m, but still distorted, weak and intermittent on the L2t. So, the L2t mixer works properly, the L2t power amp and speaker work properly, it must a connectivity or digital issue between the mixer and the power amp, then? Also the purple LED light does not come on when the unit is turned on, it never worked actually. Quote Link to comment Share on other sites More sharing options...
JensUlv Posted April 24, 2020 Share Posted April 24, 2020 Hi, Did you manage to fix this issue? I am having the exact same issue with my L2t :( (only the aux input works). Quote Link to comment Share on other sites More sharing options...
