Question to 4cm
Weezer84
On 4/2/2018 at 9:23 AM, Weezer84 said:
Hello!
Is it necessary/recommended to disable the amp models from the pod when using the 4cm? Or can I mix and match?
Greetings
Not necessary. I keep the AMP block "ON" All the time. Like you said, I mix and match both. Not an easy thing, but can be done.
