Flextone power over ethernet to Relay G10 receiver
dacu1
I want to use the power over ethernet port of a Flextone I amp to power a Relay G10:
Flextone --> ethernet cable --> adapter (like this) --> Relay G10 Receiver.
Has anyone tried this successfully, and, if so, with what adapter?
Am I right that the Flextone ethernet port is POE? I can't fine any specs on the power output.
Well, I guess I'll answer my own question. Found this page:
http://www.harmonicappliances.com/floorboard/floorboard.html
which describes the pin-out of the Line6 Floor Board RJ45 port (compatible with the Flextone I). Assuming the author is correct, a regular POE data/power splitter wouldn't work, because the Flextone output voltage is not what a splitter would expect, and the pins are in the wrong place.
