500X 2nd Expression for Volume
augustyn
Hi Guys,
since i cannot regulate the Volume during using the buildt in Pedal as WahWah i wanna add an external Expression Pedal for Volume (And use the one on board just for wah).
So i plugged in another expression pedal and it works fine BUT when i change channel the volume is reseted to zero.
That means i need to move the external pedal a little bit again to have the same volume as i had before channel switching.
Thats not useful.
Is there a way to change that behaviour?
Thanks in advance
Auge
16 hours ago, pianoguyy said:
Stored values will be recalled when you open a patch. That is correct for just about every product on the market.
It sounds as if you need to use a standalone volume pedal, not an external expression pedal.
Thanks for your answer.
Volume stays open when i use the internal pedal.
Don't need to readjust.
Using my AFX w/two Expression Pedals it also does not reset the pedal values so i tought its the same w/500x
But if there is no solution i stay with the internal. Not the optimum but i can handle it.
You are either full of koala dung or something is being lost in translation.
If what you say is true, ignore everything I have said because I obviously don't understand what you are saying.
No offending.
Sorry maybe theres something lost in translation.,
One more time.
When i use the internal pedal as a mastervolume it keeps the volumesetting when i change patches.
For example i switch from clean to crunch and dont need to touch the volume pedal.
When i use the external it doesn't. Its zero after changing patches even if the pedal is "open". I need to touch and readjust.
I ask if i can have the behaviour of the internal pedal for the external. And i added that this works w/afx i have.
Thanks again.
Auge
7 hours ago, Augeundso said:
No offending.
One more time.
Thanks again.
Auge
You need to set/save the min/max levels, and also (as I found out recently), with each and every patch you add the second expression pedal to, you need to disconnect/reconnect the pedal, then save settings, for the Pod to recognise that it is connected, and controlling the volume. This is a huge PITA when you already have the Pod fully setup with patches without a 2nd pedal, then try to add one. I recently raised the question if there is a way around it with Line 6, and THERE IS NO WAY AROUND IT GRRRRR!!!!!!
  • 4 weeks later...
this advice helped a lot! And it worked.
Since i only use 4 patches w/stompbox mode it was not so much work to do.
Thanks
Auge
