jmwhite38
Help Impulse responses onto Helix HX
I have the Helix HX, firmware is up to date. I bought some Impulse responses from 3sigma. Effects unit is plugged into my Mac. Open Helix Edit. Drag the impulse into Edit. Got to the unit, scroll to Impulse Responses and there is nothing there but the two samples. What am I doing wrong? Thanks.
All you select when you add the ir block is the number of samples. Once the block is added, you can pick which specific ir slot you want to use.
That wasn't quite what I was asking. But the answer, if anyone stumbles on to this in the future, is you load one of the sample IR's and then turn the No. 1 Knob to cycle through the various IR's in the unit.
Yes, IR is a "block" that you put in the signal chain, then in that block you have to select which IR file it will be utilizing.
