Is it possible to disable the loop function on FBV 3 ?
As the FBV3 just is a controller with no mind of its own: easiest would be a "hardware fix", in other word put a cap over the button so you cannot press it anymore.
Not sure whether the dunlop rubber knob covers would fit/be sturdy enough, but you can also just drill a hole in some piece of wood and put it over the knob and glue it down (use the nifty superglue on painter's tape trick to be able to remove it again without leaving residue)
  • 1 month later...
  • 3 months later...
