Variax 500 and Workbench on Windows 10
For anyone who is unsure of whether you can use the legacy Variax guitars under Windows 10, I can confirm that you can. I went to the download section and just selected Windows 8 as the OS and downloaded Line 6 Monkey and Workbench (non HD version), ran the installers, hooked up my Variax USB Interface and Variax 500 and everything worked perfectly first time. I had no issues with Java or the installation on the drivers.
This statement is valid as of April 2018
8 hours ago, pn2503 said:
I just did the exact same thing and am having an issue with java runtime environment. Did you download Java version 8 after Java timed out?
I didn’t have a problem with Java at all. I remembered seeing a post about the installer under Windows 10 and just unchecked Java in the installer and let it use the version already installed on my PC. I forgot to mention that step in the original post.
8 hours ago, thecameralens said:
... just unchecked Java in the installer and let it use the version already installed on my PC
Just a word of note... this may not work for everyone.
Java isn't usually installed on a machine by default... it likely came with a different software installation along the way.
  • 4 months later...
On 9/2/2018 at 10:58 AM, insulan said:
I can not find any Workbench other than the HD, that is a problem... Not under legacy product either
If you are looking for the older version of Workbench on the Line 6 site it won't show up if you limit the OS to Windows 10 in the search. Change the OS to Windows 7 and it will show up... even though it works fine in Windows 10.
