Sign in to follow this
crowden
Default volume level for a HD500 patch will not stay saved
I'm using a JTV59 guitar, POD HD500 and have all the latest patches / firmware etc.  I use the POD HD500 Edit software and the Workbench HD software to setup my patches and models.  I think I've just been looking at this too long and can't see the forest for the trees and it probably has an easy solution, so here it is.  I move a preset patch to a user location using the POD HD500 edit software. Then I tweek the patch to my liking and set the volume to match the other patches in that bank. I save that patch by sending the selected patch to the HD500 in the location that I created and tweeked it.  The volume level is correct after my save until I recall it from the HD500.  When I double click it in the HD500 Edit software it gets louder which is my prefered volume level, but when I choose the patch from the HD500 pedal it is not as loud.  Any ideas on this?
Your procedure looks right... not sure why it isn't sticking.
Have you tried changing the volume on the HD itself and saving it? Does it stick when you do it that way?
Sorry for the late reply back, yes that worked, it's all good.  Thank you for your help on this one.
