mbtainton Posted April 29, 2018 Share Posted April 29, 2018 Are the HX Fx loops naturally noisy when using fuzz or drive pedals? My HX unit doesn’t have any hiss running into either of my amps but if I put my D.A.M Drag n Fly fuzz or the Boss SD-1w into one of the loops I get a stack of hiss. Neither pedal is that noisy when not in the loops and the fuzz is happy in any position of my effects chain on a regular pedalboard. It doesn’t need to be first. Neither, obviously, does the SD-1w. The hiss is loud enough to be heard over the actual fuzz sound so even adding a noise gate is useless. Not sure why, but putting another pedal with a good buffer into the loop before either of those pedals removes the excess hiss. I’m assuming that it’s something to do with the impedance of the signal from the send jack playing havoc with some pedals. Is this part of the reported issue with some units hissing in front of particular amps or are the HX loops naturally hissy with certain pedals? If it’s just a design issue that can’t be fixed then I can work around it. But if it’s part of the other hiss issue (or another separate issue) that can be fixed then I’d like to get my unit fixed/replaced since I love using the HX. Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 30, 2018 Share Posted April 30, 2018 The loops should be quiet. I suggest you open up a support ticket. Quote Link to comment Share on other sites More sharing options...
mbtainton Posted April 30, 2018 Author Share Posted April 30, 2018 Will do Phil. Thanks. Quote Link to comment Share on other sites More sharing options...
kevanprince Posted July 15, 2018 Share Posted July 15, 2018 Interesting. I’m also having this problem. Excess hiss when using drive pedals in the HX’s loop(s). Quote Link to comment Share on other sites More sharing options...
codamedia Posted July 17, 2018 Share Posted July 17, 2018 On 7/15/2018 at 12:01 PM, kevanprince said: Interesting. I’m also having this problem. Excess hiss when using drive pedals in the HX’s loop(s). There is a sticky at the top of these forums called "HX Effects Audio Artifacts" that deals with this known issue. If you report it to line 6 through a support ticket they will asses to confirm your unit may be effected, and arrange for a replacement. Quote Link to comment Share on other sites More sharing options...
madelephant Posted July 22, 2018 Share Posted July 22, 2018 Hm...I'm also having this problem. :/ In the exact way mbtainton describes. Quote Link to comment Share on other sites More sharing options...
madelephant Posted August 5, 2018 Share Posted August 5, 2018 mbtainton, kevinprince: did your noisy fx loops problem got sorted out? Cheers, Michael Quote Link to comment Share on other sites More sharing options...
mbtainton Posted August 5, 2018 Author Share Posted August 5, 2018 Yes. Line6 replaced my unit and the new one works very well. Quote Link to comment Share on other sites More sharing options...
madelephant Posted August 6, 2018 Share Posted August 6, 2018 Thank you very much. That was the answer I was hoping for! :D Quote Link to comment Share on other sites More sharing options...
