hello, just received my L3T, plugged in the Helix and played both treble and bass side of my chapman stick into it at moderate volume. As soon as I sustained any mid low content the noisy fan came on. Is this normal? Do these L3T start pumping on the fan as soon as you solicit the bass amp? Does that change if you add a L3S bass cab?
Hi, yes, i have the same, the fan kicks in even at relatively low, home volumes...it's normal.
However, if you can hear the fan turning, then you're not playing loud enough!:-)
Sign in to follow this
