My pod hd 500 edit used to work just fine before. But i had to re install my windows for a certain hard drive crash, and after that my pod hd 500 is not responding.it works just fine without connecting the pod .But after connecting it ,the pod hd 500 edit is not responding or responding very late.I have tried it on different pc s but the problem persists.Asking for a solution
Thanks in advance \m/
Just now, hurghanico said:
surely reinstalling windows couldn't cause any harm to the POD..
if you have the same identical problem with the POD connected to different PCs, then maybe that the USB cable you are using is faulty, or the POD USB port is broken (is the plastic rectangle still present at its center?)
eventually try a global reset (and then a pedal calibration), but be aware that if you do it, the setlist names will revert back to their default
_____________________________________________________________________________________________________________________________________________________________
All about POD HD500/X
new forum
Yes i tried it with a different pc, the problem persists. All the other line 6 softwares work perfectly except the edit.
The edit opens but doesn't response.if i press any switches on the pod , the change is seen in the edit so does the tap tempo changes if i set the tempo through the pod.
I have done the procedure of global reset by holding the left arrow and plugging in the power cable. It didnt show anything that the pod has been
Reset ,just the line 6 logo came up then the first preset came up.I also did the pedal calibration.
The usb port seems fine.The pics are
given below
Thanks hurghanico
Please tell me what to do next
Best regards \m/
did you somehow install an older version of Edit, like from a backup somewhere, and forget to update it to the latest?
This does sound like a PC issue, not a Pod issue.
nope i am using all the updated softwares a,flash , firmware.the same problem persists when I use it on another PC
Hey everyone
the problem was a cable issue
it is now fixed
thank you everyone for your valueable time
Peace ^_^
