Sign in to follow this
Phil110567
HX FX Instant access assign to preset
Hi there,
I'm considering using instant access in order to assign external amp setting changes.
I've read there are up to 6 instant access to choose from.
Once my instant access configured, how can I assign them to presets ?
My aim is to be able to change amp settings depending on the preset.
You're talking about the Instant Commands, I take it. You don't assign them to presets... Each preset can have up to six Instant Commands. You just program them how you want them in each preset.
Ok ! Thanks !
I understand that I have 6 "Instant command" per preset. So anytime I go in the "Command center" if I program the Instant commands, it affects the current preset. Am I right ?
Does it mean that anything in the "Command center" is related to the current preset ???
1 hour ago, Phil110567 said:
Ok ! Thanks !
Yes, everything in the Command Center affects only the current preset (and snapshot, but if you're not using snapshots, don't worry about that).
9 minutes ago, Phil110567 said:
Maybe the manual should say it ...
It's clear now ! Thank you so much !
Well, not trying to be a jerk, but it does say it... :-) ..."All Command Center assignments are stored per preset..."
