hereticaltruth Posted June 16, 2018 Share Posted June 16, 2018 I'm having an issue where Logic X won't work if Helix is the output device. And by not work, I mean no sound is transmitted and the meters don't even light up in Logic so it acts like no signal is being read. Trying to change to built in output while Helix was connected caused Logic to hang/freeze. I had to disconnect the Helix, relaunch Logic and change the output to the built in output and then Logic works just fine. Is anyone else experiencing this? Any work arounds? Fwiw, I'm running a 2013 27" iMac , Helix fw 2.54, and 10.14 dp1. Quote Link to comment Share on other sites More sharing options...
hideout Posted June 16, 2018 Share Posted June 16, 2018 OS X Mojave? That hasn't been released yet. If you're using a beta version you shouldn't be expecting everything to work and you should be telling this to Apple and Line6 directly. Quote Link to comment Share on other sites More sharing options...
hereticaltruth Posted June 16, 2018 Author Share Posted June 16, 2018 the developer's preview has been released. I do report bugs. Just looking for anyone else who has experienced this and if a solution is available. Thanks. Quote Link to comment Share on other sites More sharing options...
Foriegninsect2 Posted October 28, 2018 Share Posted October 28, 2018 I am having the exact same issue. It won't let me adjust the audio levels on the 8 midi channels. Quote Link to comment Share on other sites More sharing options...
