Helix ground noise - MIDI switching vs. hum destroyer
BoogieV
Hi all,
I had the opportunity to try out a Helix LT in 4cm with my amp today and am very impressed with it. Unfortunately a noticeable (but expected) ground hum was present, especially on higher gain settings. This became more apparent when I used the 1/4" ext amp for amp channel control.
Before I pull the trigger on the Helix I want to know that I can minimise this noise at least to a manageable level. Will using a midi controlled switcher as opposed  to the ext amp output eliminate some of noise? Or am I better off with a hum destroyer (ebtech/radial etc)?
Any advice is greatly appreciated.
