Sign in to follow this
jesuscares
Tap Tempo question.
Can someone tell me how to set delay to Tap Tempo,specially when you are using more than 1 delay on the chain ? I generally like to set all delays on the chain to tap tempo .
On the time parameter, push the knob below it and it will switch from time in milliseconds to note selections.
  • Thanks 1
If you're talking about the HX editor there is a little clock icon to the right of the top parameter slider. Click on that and I believe it will then list notes instead of ms.
  • Thanks 1
Thanks guys.I was looking for the 'Tap' word like in older PODs.So all the note selections given in fractions are set to Tap tempo I guess.
Yep, you got it. If you touch the tap foot switch (not press) then you can manually assign the tempo as well. I prefer programming it rather than tapping it. I don't get consistent results with the tap and is kind of frustrating.
