Sign in to follow this
jesuscares
Globally turning off/on amp/cab models.
Is it possible to globally turn off/on amp/cab models.This may be handy when plugging into an amp or cab or even a amp/cab modeler.
Someone else may chime in but I don't think blocks can be globally assigned. What you can do is to copy an entire setlist (or just one preset) in HX edit and then save your changes. I did this yesterday since I use 4cm for live performance but only straight in for rehearsal and it makes it very easy to call up two different scenarios.
  • Thanks 1
+1...
This method also allows you to edit the patch for optimal tone with a different device without destroying your original copy.
  • Thanks 1
Nope... The fact the Helix allows complex signal chains with multiple amps/cabs/IRs would make it pretty tricky to have these sort of global options. Basically, other units can do it because they have a dedicated slot where the amp/cab model always goes. There's no such thing on the Helix. You can put the amp/cab models anywhere you want them in the signal chain. So having fewer global options is the trade-off for having more flexibility elsewhere.
