fullmonty93 Posted June 21, 2018 Share Posted June 21, 2018 Hi Line 6 forum, My question is: Is it possible to use the gaming headset microphone as an input into the UX2? If yes, How is this achieved? I've unboxed from new and fully installed PODFarm v2.59 & Line 6 Monkey/ Authorized my UX2 to my PC. My objective is to use the UX2 as a voice morphing/ changer for creative gaming purposes. My audio and microphone headset is a Logitech G633 running the up to-date v99.0.10 software. I've browsed many forums and tutorials over the past 6 hours and have tried the basic adjustments i;e: Adjusted the UX2 dials and enabling the phantom +48V button, changing the POD Farm mixer INPUT: Mic 1 and tried the various other inputs, enabling UX2 as default through Windows 10 sound settings and disabling all other audio and recording inputs/ outputs. Any clarity or result would be much appreciated, cheers. Quote Link to comment Share on other sites More sharing options...
Triryche Posted June 21, 2018 Share Posted June 21, 2018 I’m guessing this is a USB device. Unfortunately the UX2 is not designed to work with a USB mic. You may be able to come up with a workaround. I’m not familiar with the software you mentioned, but you may be able to use a DAW and run PF2 as a VST plug-in. Quote Link to comment Share on other sites More sharing options...
fullmonty93 Posted June 21, 2018 Author Share Posted June 21, 2018 Thanks for the reply, The G633 headset has both switched USB and 3.5mm Jack outputs. Would it be a possible solution to run an adapter cable between the XLR Input and the 3.5mm Headset Output? Example: https://www.jbhifi.com.au/audioline/audioline-3-5mm-to-xlr-mono-pro35xlr/888812/ Cheers. Quote Link to comment Share on other sites More sharing options...
Triryche Posted June 22, 2018 Share Posted June 22, 2018 The issue would be if you did get the mic to input via an adaptor, you will not have sound in your headset. Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted June 23, 2018 Share Posted June 23, 2018 You might be best to ask line6 directly with this query. Log in to your account at line6.com and open a support ticket with them Quote Link to comment Share on other sites More sharing options...
