line6, please fix that!!!
rudomat
that really drives me crazy, that i always have to move the xpression pedal first while searching for the right parameter, to hear the changes...
of course it should be possible to hear the changes in real time and not have to move the pedal first to be able to hear the changed parameters...
5 hours ago, phil_m said:
I don't understand what you're asking for...
sorry, phil...i´m not native english speaking...when i change the settings for minimum and maximum for my expression pedal i don´t hear the new setting....i first have to move the pedal to get to hear the new setting...understand...?
thanks
5 minutes ago, rudomat said:
wow....very funny people you are...very funny...maybe you should try another forum...?
Are you referring to pedal edit mode with your feet, or what? Your initial question did not make sense?
I'm pretty sure what he is saying is...There are other pedal board units that as you change the max and/or min of, for example, a volume pedal, you can hear the changes as you do them. He's saying the Helix doesn't act that way so, apparently, you have to actually move the pedal before you hear what effect the changes have. Rudomat, is that close? I haven't tried this myself so I can't confirm it but I think that's what this is about.
thank you...exactly what i tried to say...
hopefully this helps I know that I had problems at first properly assigning parameters to the expression pedal or footswitches. I would think it is moving the parameters after “programming it” but I would hear no changes. That is when I figured what I was doing.
The same thing happens with footswitches. I use a Drive footswitch to change amp drive from min to max values. If I edit the controller and change the min and/or max value, the change doesn’t take effect until I press the footswitch.
