sammypackle Posted October 24, 2013 Share Posted October 24, 2013 Hello, Is there a way to route say, reverb, to the monitors only, and not have any go to the mains? Thanks! S Quote Link to comment Share on other sites More sharing options...
linesixy Posted October 24, 2013 Share Posted October 24, 2013 I'm not an expert... but I think people normally try to do the opposite... i.e. only have effects on the mains and use a dry signal on the monitors. I think there can be a tendency for singers to sing slightly out of tune if they have reverb on their monitor signal. Having compression on the monitor signal may also result in other issues as well. Quote Link to comment Share on other sites More sharing options...
Digital-sound Posted October 25, 2013 Share Posted October 25, 2013 I do believe you can do that. Click the "monitor" hardware button, and then at the top of the screen, you select "FX to monitors". I am pretty sure it is independent of the front end. Ie. you can have lots in the monitor and make it pretty much in audible out the front end. Not sure about actual "0", but pretty close. Quote Link to comment Share on other sites More sharing options...
kolelsam Posted November 5, 2013 Share Posted November 5, 2013 I can confirm the above post by 'Iknowathingortwo'. It is possible to do this. Select the Monitor Button and FX to Monitors. It is independant of the mains. Quote Link to comment Share on other sites More sharing options...
