craignaso Posted June 28, 2018 Share Posted June 28, 2018 I've had the fbv3 for a year now w no issues, I went to turn on today and on the screen it only shows FBV 3 v1.00.00 the pedal won't turn on at all...how do I fix this??? I literally just played this at a show the other day and it worked fine Quote Link to comment Share on other sites More sharing options...
ADBrown Posted June 29, 2018 Share Posted June 29, 2018 I recommend updating the firmware first, the current version is 1.01. Connect your FBV3 to a computer via USB and run the Line 6 Updater program, free at line6.com/software. If updating the firmware does not solve your issue the next thing to troubleshoot would be the cable. The FBV 3 cable is a cat5 cable, so if you have a spare ethernet cable lying around you can test to see if the cable is faulty. If none of this works to fix your problem contact customer support. Quote Link to comment Share on other sites More sharing options...
