craignaso
FBV3 not working w my 240hc
I've had the fbv3 for a year now w no issues, I went to turn on today and on the screen it only shows FBV 3 v1.00.00
the pedal won't turn on at all...how do I fix this??? I literally just played this at a show the other day and it worked fine
I recommend updating the firmware first, the current version is 1.01. Connect your FBV3 to a computer via USB and run the Line 6 Updater program, free at line6.com/software.
If updating the firmware does not solve your issue the next thing to troubleshoot would be the cable. The FBV 3 cable is a cat5 cable, so if you have a spare ethernet cable lying around you can test to see if the cable is faulty. If none of this works to fix your problem contact customer support.
