Sign in to follow this
mbtainton
HX - separate effects chains out to two amps
Anyone running a patch with separate effects chains out to the L and R outputs without them being mixed together at the end of the chain?
i want to run out to two amps and have a EQ block only apply to one amp.
Easy. Create your EQ block, use the action button to move it "down" and create a new signal path. Find the point where it joins the original signal path again and use the action button to move that down so that it's a separate output. Configure your outputs so that one goes out the Left 1/4" and the other goes out the Right 1/4".
On the HX I can create the parallel signal path and I can find the merge point where the mixer is. I can drag the mixer down to the parallel path and then path A shows an output of Main L/R and path B shows an output of Send 1/2. I can see where these can be changed.
Does this mean that to run separate chains into separate amps I have to run one amp lead out of output A and the other out of the send jack for one of the loops?
