Abokerr
Effects in path1 disappeared after update
Help required. I just done the 2.60 update and one preset all the effects that were on path 1 ( top row ) are gone how can i get them back ?
Thanks in advance.
Is this happening in multiple presets?
Did you create a backup prior to installing the update? I would perhaps try restoring from the backup to see if you can get it back.
It happened to me too (one preset, and 2 copies I used to experiment). Backup didn't help.
I should have asked earlier, but did you install the latest version of HX Edit?
I didn't first time, I got confused , then I did and tried again still nothing.
It was the preset that my helix was in at the time that lost data transfer don't know if that makes a difference
1 minute ago, meshax said:
Is it possible to revert to 2.54 from 2.6 ?
It is. You can do it through Line 6 Updater.
This is most likely a corrupt preset, though. There might not be a way to recover it.
This preset was not new, it worked fine with last 3-4 updates, until 2.6.
A question for experts
phil_m said that preset was corrupted and after update to 2.6 top path was missing. But, how to spot a corrupt preset?
I've experienced system freeze  before, with a patch and I deleted it, and I'll rebuild this one but is there a way to check preset "helth" ?
