doublescale1 0 Posted July 7, 2018 So I've watched the two videos on setting a virtual capo - when I push my model button down and get it and the tuning select wheel to blink, as soon as I move the tuning select to where I want to store openE (modal in this case), the tuning select knob stops blinking and I get nothing saved... every time. It seems as if this does not want to be this difficult - any suggestions on how I can store OpenE tuning in what is now the factory "Model" position on the tuning wheel? Quote Share this post Link to post Share on other sites
codamedia 848 Posted July 9, 2018 Maybe you should check out the JTV and Workbench HD forum? https://line6.com/support/forum/39-james-tyler-variax-guitars-workbench-hd/ You've stumbled into the older model (300, 500, 600, 700) forum and most of us likely don't know the answers for you. Quote Share this post Link to post Share on other sites
jakeman19 6 Posted July 10, 2018 According to the JTV Pilots Handbook "You can replace all but the MODEL and STANDARD setting on the Alternate Tuning knob with your very own creations." So that's why it won't work for the Model setting. Hope this helps. Jd Quote Share this post Link to post Share on other sites
Matt_Brown 16 Posted July 11, 2018 I thought you had to move the selector before you pushed it? Quote Share this post Link to post Share on other sites
jakeman19 6 Posted July 13, 2018 On 7/7/2018 at 5:52 AM, doublescale1 said: So I've watched the two videos on setting a virtual capo - when I push my model button down and get it and the tuning select wheel to blink, as soon as I move the tuning select to where I want to store openE (modal in this case), the tuning select knob stops blinking and I get nothing saved... every time. It seems as if this does not want to be this difficult - any suggestions on how I can store OpenE tuning in what is now the factory "Model" position on the tuning wheel? Also after watching some of the videos I see where you might be having the problem. First, you can't store open E to Model like you want to do, the way you may think it works. Model would then store the open E to Spank 1 if that's the tuning you want for Spank 1, if you had it on T-Model 5, it would save it there. It saves the tuning with the model selected. I'm guessing you just want to have an Open E tuning on one of the tuning positions(tuning knob), just choose any other one other than Model and Standard. When you push the Guitar model selector after, it goes to audition mode, you'd have to hold the Guitar selector knob for about 2.5 sec for it to save the new tuning. I hope I made sense in my explanation but if you need more clarification then please post. Jd Quote Share this post Link to post Share on other sites
