mdorren
Synth via efx loop return
Trying to use my synth with my hx effect via efx loop return.  My bass is the main input so it's going to the input in jack but i have a twelve step foot pedal board midi connected to a korg volca fm. The out of the volca is going into efx loop one return. Shouldn't this work?
You need to put a RETURN block in the signal chain, probably at the end so it doesn't go thru the effects.
Worked lile a charm!... Strange thing though... I have a return 2 but not a return 1... hmmm... Anyway, many thanks!
Are you using "effects loop 1" already? If so, return 1 will not be available.
