codamedia Posted July 12, 2018 Share Posted July 12, 2018 Running an HX Effects, I seemed to have hit a snag with v2.6 that I don't recall ever noticing with 2.54. I run multiple instruments and utilize the 2 paths and multiple inputs extensively. Machine is loaded with 2.6 & I have done a full reset for testing. I originally noticed this on existing patches, but I did create a simple test patch from scratch and can re-create the problem every time. Expression pedals, and expression pedal settings do not have any effect on the results. The problem If I use both inputs with separate instruments, PATH B does not return for the right input after using the tuner. A Recipe to try... (I would appreciate people trying this and reporting back... please don't make any assumptions and follow the recipe closely) Start with a blank patch Load a tremolo in the first slot, and a reverb in the 2nd (any effect will do, I use these because they are in your face and obvious) In the signal flow page, drop the Reverb to path B Make sure the input Y is moved to the front of the chain. Leave all settings to default... no need to adjust the Y IMPORTANT: Plugin two different instruments to the L/R inputs... If you only have one instrument you need to use a dummy jack in the other input for proper testing. NOW THE TEST INITIAL RESULT: You will hear both effects from both the L and R input. This is the correct result. Now engage the tuner, then turn the tuner off (do not change patches) RESULT: The left input still sounds correct. The right input will not have any reverb (path b), just the tremolo from path A NOTES Changing patches and returning will correct the problem until you engage the tuner again. If you hard pan the inputs to the paths, the right input becomes completely silent in this test There are many more scenario's I have tested to varying degrees of results... but the one provided here appears to be the simplest and most obvious. Quote Link to comment Share on other sites More sharing options...
codamedia Posted July 12, 2018 Author Share Posted July 12, 2018 I just want to add one more thing I have tested with this... The problem exists regardless of the tuner mode. I generally use the tuner in mute mode... but L/R or Send2 mode makes no difference. Quote Link to comment Share on other sites More sharing options...
codamedia Posted July 17, 2018 Author Share Posted July 17, 2018 I am updating this thread... just in case anyone else encounters this problem, or anything that may be related. Line 6 has verified this problem and confirmed it is a bug that will be fixed in a future update. 1 Quote Link to comment Share on other sites More sharing options...
