fullmonty93 Posted July 15, 2018 Share Posted July 15, 2018 Hi Line 6 forum, My question is: Has anyone been able to successfully connect the Razer Sieren Pro with the UX2? If yes, How is this achieved? I've unboxed from new and fully installed PODFarm v2.59 & Line 6 Monkey/ Authorized my UX2 to my PC. My objective is to use the UX2 and PODFarm as a voice morphing/ changer for creative gaming purposes. The Razer Sieren Pro (https://www.razer.com/gaming-audio/razer-seiren-pro) has three outputs: USB, Headphone/ AUX female jack and a DMX 5-pin output with a Y split XLR adaptor cable (one 5-pin into two 3-pin) - (https://www.markertek.com/product/5pin-523b/5-pin-proaudio-523b-5-pin-xlr-female-to-dual-3-pin-male-y-xlr-cable-1-5-ft). The Razer Sieren Pro works correctly when connected directly to the PC, however the PODFarm voice morphing software doesn't transmit out through the Microphone. I've browsed many forums and tutorials and have tried the basic adjustments i;e: Adjusted the UX2 dials and enabling the phantom +48V button, tried multiple UX2 line/ microphone ports/ inputs/ outputs with the above mentioned cable/ AUX cable and also an aftermarket adaptor cable (one 5-pin to one 3-pin) - (https://www.storedj.com.au/hosa-dmx-306-3-pin-xlr-m-to-5-pin-xlr-f-dmx512-adaptor-cable-6) , changing the PODFarm mixer INPUT: Mic 1 and tried the various other inputs, enabling UX2 as default through Windows 10 sound settings and disabling all other audio and recording inputs/ outputs. Still no success. Any clarity or result would be much appreciated, cheers. Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted July 15, 2018 Share Posted July 15, 2018 Have you set your ux2 as your soundcard yet? Quote Link to comment Share on other sites More sharing options...
fullmonty93 Posted July 15, 2018 Author Share Posted July 15, 2018 Thanks for your help. Isn't "Enabling UX2 as default through Windows 10 sound settings and disabling all other audio and recording inputs/ outputs." exactly the same as setting the UX2 as the soundcard? Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted July 15, 2018 Share Posted July 15, 2018 Pretty much, yes. Have you another mic to test if the ux2 is functioning correctly. Can you hear any music/ sounds out of your speakers? Making sure the ux2 is operating correctly would be the first step. Using the standard xlr out on the mic should work. Quote Link to comment Share on other sites More sharing options...
Triryche Posted July 16, 2018 Share Posted July 16, 2018 Is this a USB mic? The UX2 does not inerface directly with USB mics. Quote Link to comment Share on other sites More sharing options...
fullmonty93 Posted July 17, 2018 Author Share Posted July 17, 2018 Thanks for your help. "The Razer Sieren Pro (https://www.razer.com/gaming-audio/razer-seiren-pro) has three outputs: USB, Headphone/ AUX female jack and a DMX 5-pin output.". The USB connection does both: supply the Microphones' power and connects the Microphone to the PC. Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted July 17, 2018 Share Posted July 17, 2018 It wont work with the usb. Try using just the xlr out with phantom power on your ux2, not a seperare source powering the mic. Assuming you have tested that the ux2 is setup/working correctly, you will be able to plug your mic in and confirm if its compatible with the ux2. Quote Link to comment Share on other sites More sharing options...
