jayrennicks 0 Posted July 15, 2018 First post. Using hx. So when using reverbs (or any effect), it would make sense to me if the parameters displayed in the first window were those that were most often used, like depth (or mix) and decay. I often like to change parameters on the fly, but i have to spill out all the parameters and the one i want is often on the second or third window. I'd like it if my most changed parameters were on the first window, so that i could use knobs 1-3 to quickly adjust things like depth, mix or decay. Instead when I click on Glitz reverb, the parameters that show up are decay, predelay, and low cut. I'm not in the habit of adjusting predelay or low cut very often, but I change decay, mix, depth all the time. What I would really like is if I could choose which parameters show up in the first window. Any suggestions here? Quote Share this post Link to post Share on other sites
duncann 758 Posted July 16, 2018 Can't be done. Only suggestion I have is to post an idea on https://line6.ideascale.com/. It's an interesting idea, in particular for people who like things like this to be in an exact presentation, and for the sake of efficiency. I'd vote for it. Quote Share this post Link to post Share on other sites
jayrennicks 0 Posted July 16, 2018 Ok Thanks Duncann. Too bad. With my old m9 i felt like the relevant parameters were always visible and you could use the few knobs you had to adjust them on the fly. I'll post the idea as you suggested. If they can't make the order customizable, they should at least try and guess which parameters people will want to see in the first window. Three parameters is enough to work with on the fly, but 8 is too many and its too many clicks to get there. Quote Share this post Link to post Share on other sites
