Helix as usb midi interface
Izzy3
i have one stupid question. It's posible connect roland drum to midi, and then send midi from helix to pc via usb to addictive drums , and then return the signal to helix and send the signal to amplifier? It's so weird, i know.
Sorry for my english.
Thank you.
I was assuming that you had a controller (midi drum pads) that you wanted to use to play Addictive Drums.
In Helix Globals- MIDI/Tempo - set MIDI Thru to ON and MIDI Over USB to ON.
Plug your pads into the Helix MIDI IN.
Be sure that AD is listening on the same channel that your drum pads are sending on.
